create max min feature for waveform graph
I am trying to create a max/minimum feature for my system, however, I am not sure how to wire this correctly. Also how do you put the graph background lines on the waveform graph?
Thank you in advance!
Stuart
Message 1 of 8
(5,024 Views)
What exactly do you mean by a max/min feature?  That could be any number of things.
GCentral
Message 2 of 8
(5,015 Views)
Please clarify: do you want to plot the actual min and max as separate lines?  If so, it would be easier to do with a waveform graph, so you can update the plots as the min/max value changes.
"There is a God shaped vacuum in the heart of every man which cannot be filled by any created thing, but only by God, the Creator, made known through Jesus." - Blaise Pascal
Message 3 of 8
(5,014 Views)
Hi Stu
Please check out the 'Waveform Min Max example.vi' which can be found under 'Help' and then 'Find examples..' from the LabVIEW menu bar.
To add some coloured lines right click on the graph and select 'Properties' - select the 'Scales' tab and then at the bottom right select colours for 'Major Grid' and 'Minor Grid' where it's titled 'Grid Style and Colors'
Kind Regards
Chris | Applications Engineer NIUK
Message 4 of 8
(5,013 Views)
To be honest I am not sure, the criteria I have asks me to add a max/minimum feature to my system. Also the values should be able to be reset by a control switch. I was hoping if I put the question on here together with my VI, it might have been clear to someone what it meant.
Regards
Stu
Message 5 of 8
(5,001 Views)
Sorry I dont seem to be able to find the VI Smiley Frustrated
Thank you for the help with the graph, I have altered this.
Message 6 of 8
(4,999 Views)
Hi again Stu
Which version of LabVIEW are you running?
I'm using 2011 on Linux on this computer and I can find it by opening up the NI Example finder (Help > Find Examples...), Changing the tab on the left hand side to search and searching for the term 'waveforms'. A big list of examples with this keyword should appear, the min-max example is fourth from the bottom of the list on my installation.
Kind Regards
Message 7 of 8
(4,992 Views)
Yes apologies I have found it. I will give that a try.
Thanks again.
Message 8 of 8
(4,978 Views)
