create string element from array
Problem... I want to create a single String element. My input is a 1D Integer array of two elements e.g. [10, 5] and the output needs to be a String element in the form of "10,5". Just a single element and not an array. Any tips or ideas?
Thanks!
(4,787 Views)
Accepted by hannesostergren
Array to Spreadsheet String.
You may need to delete the end of line character that would show up.
Alternatively, if you know it is always 2 elements.  Index Array, and feed the two outputs to Format Into String with %s,%s format code.
(4,782 Views)
Use Array to Spreadsheet String from the String palette with the delimiter set to comma.
Lynn
(4,781 Views)
Index Array.vi to get the elements, then Format into String.vi to create the string.
EDIT:  Forgot about Array to Spreadsheet.vi.  Smiley Embarassed  That combines both functions.
(4,780 Views)
