create video from individual pictures by LabVIEW
I have transformed  the .avi into image and got pixels array,and I want to recover .avi(a video format)from the pixels array
Message 11 of 16
(1,506 Views)
回复1.pngIs that right?回复2.pngI run it ,it exits an error
Message 12 of 16
(1,505 Views)
really appreciate for your helpHeart
Message 14 of 16
(1,493 Views)
is it possible to generate AVI (video) from images without paid modules. This means using LabVIEW Base + Free modules only?
I found this article...
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019KV1SAM&l=cs-CZ
But I'm not sure if IMAQ driver is for free or I need to buy at least Vision Acquisition Software
http://www.ni.com/cs-cz/shop/select/vision-acquisition-software
Message 15 of 16
(1,334 Views)
OpenCV can both capture video's and create AVI files. It's free, but not that easy to get working. My library isn't good enough to share, but I've used OpenCVSharp's OpenCV dll (the normal dll that .NET uses). There are OpenCV libraries for LV dangling around. I hope dlls\.net are supported in LV Base...
IIRC, IMAQ requires a runtime license, but comes with NI Vision. Maybe you can legally use IMAQ for free, but the Run-time license is just as expensive as NI Vision, that doesn't require a run-time license. Something weird like that was going on. Please check the details yourself.
Message 16 of 16
(1,302 Views)
