creating a waveform from a set of data points
I have a set of Y values which are spaced 1/sampling rate apart. I am trying to build a waveform with them, but buildwaveform.vi does not seem to be working. Any suggestions? Thanks.
Intern NSWCCD Carderock.
(2,520 Views)
Did you try the build waveform function.
Look at annex,
Hope it helps,
Paulo
(2,513 Views)
Play with examples, that's the easiest way when you 'need to learn fast'.
There is one named 'Create Waveform example' that shows you the way BUILDWAVEFORM.VI works
I hope it helps,
Aitortxo
Aitortxo.
(2,511 Views)
