creating instrument driver VI locks up labview when more than one parameter used
When using the create instrument driver VI wizard labview locks up whenever I use more than one parameter. I can generate a VI that uses the follow text/parameter:    CL %Channel%    but if I try and do      CL %Channel% %Mode%
When I push the finish button labview locks up and has to be restarted (see attachment). I've tried this on two computers. I am using the configure your own VI option and running Labview 2012. Any idea what I'm doing wrong?
thanks
K
(2,422 Views)
How do you know that CL takes two parameters?
(2,410 Views)
Because the programming manual states it does. Also I don't get any errors when I verify be clicking the run test. I've tried numerous command strings going so far as to run a command string that was used in an NI tutorial video that has two parameters and the system locks up.
(2,392 Views)
