creating pulse/waveform based on user input
Dear Friends,
I would like to create a waveform/pulse based on two input arrays, each array containing the time durations (in seconds) for high and other for low. I want to read them and create a waveform (pulse).
Eg.
high_array = [h1, h2, h3, h4, ...]
low_array = [l1, l2, l3, l4, ...]
The pulse should look like this:
h1 l1 h2 l2 h3 l3 ... and so on
If you have developed any prototype or can guide to appropriate example would be highly appreciated.
Jeguna
(2,860 Views)
I am not sure any direct VI is available for your requirement. I think you can build the waveform in the loop.
I have attached the code, see whether it helps.
Logic
(2,858 Views)
Thanks Logic, that was of great help.
(2,839 Views)
