creating subvi within for loop problem
Hi guys
I am trying to create subvi but part which come inside subvi contain for loop. As soon as I selected part of my program for which I want creat subvi it one pop up comes. I am posting images of the pop up and program. In this program image I want to create subvi for (For loop with 10 iteration).
Please help me in finding solution. I will appriciate your help.
(3,661 Views)
Accepted by parag77
A lot of your local variables should be simply replaced with wires or shift registers.  That would eliminate some of your issues.  Otherwise, I would just delete your indicator terminals before creating the subVI.
(3,649 Views)
Thank you for your relpy. I tried what you said but it didn't reslove issue ,its showing same pop up
(3,644 Views)
Then you didn't eliminate all of the locals or indicators. Do you understand how the functionality will actually change. I suspect that when you succeed in making it a subVI, your next question will be why the front panel does not update until the subVI finishes.
(3,619 Views)
Thank you for your reply. Icreated sub-VI, there was problem with conneting wire subvi doesn't  take local variable for consideration.
Can you please explain the problem you mention becasuse as my main VI updating simulateneously suv-VI also updating.
(3,615 Views)
Any indicator on the front panel simply cannot be updated as the subVI runs unless you modify the subVI to use something like a reference. Just basic dataflow. Really basic programming, for that matter.
(3,608 Views)
Dont mark the posts as solution if your problem is not solved.
From your posts. You have also another thread where you mentioned detecting ellipse.  I feel you are doing it the hardway. Have you tried coverting the image to binary and using a particle filter
(3,596 Views)
