crio 9073 output problem
hi i am new to labview and about to start crio..i am using crio 9073 in fpga interface mode.. i am having ni 9263 module with that i am trying to understang fpga crio working... i started the proj and i added anolog output example given.. i am able to compile the fpga file amd all.. but while running host file i not able to see the output in the corresponding port..
(2,749 Views)
how are you checking the output of the port. Do you have some input card as well. If yes you can loopback the signal and check if you are getting proper readings or not.
(2,730 Views)
