waveform graph legend
Hi
I have connected 4 waveforms to a one waveform graph control and I have labelled them and changed thier colour using waveform graph legend control but although I saved everything but when I close labview and open my VI again all the colours has changed also the names.would u please help me how can i label my traces and save all the changes to not face this problem?
thanks
(5,098 Views)
Did you set the labels and colours using a waveform graph property node or did you just change them via the front panel?
CLAD
(5,090 Views)
Dear En99
What version of LabVIEW are you using? I have just tried this and it kept the labels and colours. Make sure you save the VI properly by selecting File >> Save VI.
Also, are you using property nodes to select the labels and colours? For example, right click on the graph/chart, Create >> Property Node >> Plot. Color  for example or are you selecting these off the graph?
Many thanks for using the NI forums and I look forward to your reply.
Kind regards
David
National Instruments UK
(5,071 Views)
