crio 9082 usb device
Hi
I need to connect a usb device and read in serial mode. The device is recognized in MAX as
USB0::0x403::0x6001::A703D8LA::RAW
When I set the visa resource as the above line and try to read it, it gives Error code 1073807331.  The interesting thing is that I have successfully connected to the USB device from the usb port of sbrio 9607 before with the same program. In sbrio the device is seen as ASRL8:INSTR which is a major difference from the crio 9082.
Dees anybody have an idea about this difference between two NI platforms?
Thanks in advance
Engin
(2,898 Views)
The 9607 runs Linux RT and the 9082 rus Pharlap ETS:
http://digital.ni.com/public.nsf/allkb/35F1FD98520D6E0E8625783A005AF557
You'll probably have to stick with LinuxRT cRIOs for the device to work ask you expect Smiley Happy
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
(2,868 Views)
