cro like waveform
Accepted by topic author rk_t
Look at the "stream" examples. The Labjack is near its speed limit since you need to acquire with a rate that is at least twice the signal frequency.
(quote from hereHardware timed input streaming has a maximum rate that varies with resolution from 2.5 ksamples/s at 12-bits to 50 ksamples/s at about 10-bits.).
Message 11 of 12
(1,186 Views)
Thank you very much!! got it! 🙂
Message 12 of 12
(1,171 Views)
