crop a circle bounded by a square and obtain pixel data
If I have a square picture which bounds a circle, how do I crop it and obtain only the pixel grayscale data within the circle?
(2,664 Views)
You can't do cropping in LabVIEW without additional toolkit.
You can get all pixels within the bounding square in 1D array using Invoke Node>Get Image. Then convert 1D to 2D array use Unflatten Pixmap.vi. Use the array index to determind whether the pixel is inside the circle or not.
If you're dealing with a color picture, you better to convert it to grayscale before handle, because it's slow.
George Zou
http://gtoolbox.yeah.net
George Zou
(2,664 Views)
