crosscorrelation time delay question
Hi!
I have a project, where i work with 2 microphones, and i want to calculate the time delay between the two signals. I had made a simple method for it, but it's a bit bad...
So now i  try it with crosscorrelation, but i can't get a correct time-format...i had made the correlation correct, i have just some problem with the time format...
If i convert the time format into string with %<digit>, then i always becom 0...
Here is my vi, can somebody help me?
(3,018 Views)
I took a peek- your problem is with the format string on the timestamp to string functions.  Your format strings are "%5u" and "%S"  the %5u returns a string that represents 5 digits of fractional seconds, the %S converts only the whole number of seconds
FROM the help-
for format timestamp to string
..." Time format codes include the following:
%a (abbreviated weekday name),
%b (abbreviated month name),
%c (locale-specific date/time),
%d (day of month),
%H (hour, 24-hour clock),
%I (hour, 12-hour clock),
%m (month number),
%M (minute),
%p (a.m./p.m. flag),
%S (second), %x
(locale-specific date),
%X (locale-specific time),
%y (year within century),
%Y (year including century),
%<digit>u (fractional seconds with <digit> precision).
So, How do you want to display the time information?  If you want 1 January 1900 12:00:00.000AM to display as "1/1/1900 12:00:00.0am" your format string should be "%d/%m/%Y\s%I:%M:%S%1u\s%p"  (ESCAPE CODES DISPLAYED)
(3,007 Views)
