csv starts in collumn b after a newline
Hi Guys,
I'm building a csv with 4 rows of data added each time the vi is run. For some reason lines 2-4 start in collumn B, not A like they should. I tried deleted the first index of the array, but that didn't help.
All incoming arrays are the same size, as well as the arrays being added to the file.  Its probably easier to see what's going on with a screen shot.. there are a bunch of sub vi's.
Here is my code -
and here is what the csv looks like -
I know it is an obvious solution.. i'm just blind right now, lol!
Thank you!
Christopher
(3,387 Views)
Could you post the actual code and an example of the csv file being generated.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,385 Views)
Sure, three subvi's are attached, and 2 more in the next post.
Thanks!
(3,380 Views)
Here are the main VI and the csv.
(3,379 Views)
Accepted by topic author Pickering
Hi Pickering,
your path handling is kind of wierd: converting from string to path and vice-versa all the time! Why don't you stick with path datatype?
- Building arrays is done best using BuildArray. InsertIntoArray is kind of overkill here!
- Don't include your own LF/CR elements in the array. This is handled by the WriteToSpreadsheetFile function internally!
(3,367 Views)
Perfect!  Thanks for the tips as well.
(3,360 Views)
