myRIO LabView Network Configuration, can't [SAVE] running connection to activate WIFI.
Recently aquired a new myRIO from NI.  Now trying to implement the WIFI option on NI Network Configuration Page.
Following the instructions, connected the the router, getting 5 green bars. and a big check mark.
The instructions ask to press the [SAVE] button, but the save button is not active, only two
other buttons are active, the [Certificate Management] button and the [Refresh] button.
I clicked the [refresh] button, but nothing happened.  I am not sure what to do with the
[Certificate Management] button, since the instructions do not address it.
So, myRIO status indicates that it is connected to the router via the USB cable, and not by WIFI.
If the USB cord is disconnected from myRIO, a message pops-up saying "Connection to target Lost!"
(5,846 Views)
Can you click the certificate management button? Perhaps you need to accept the certificate.
Thomas N.
(5,805 Views)
When I click on the certificate management button, a window pops-up, which
gives an option to upload a certificate (document), which I do not have.
see attached image
(5,767 Views)
The certificate will usually be supplied by your network administrator. Also, can you provide a screenshot of your settings page with the button disabled, as well as the instructions you're referring to for clarity?
Brandon V.
(5,734 Views)
I am running SOLO, do not have an administrator.
Attached is the screen image of the steps taken
as requested.
(5,726 Views)
Please also find attached, the instructions followed, that
were requested
(5,719 Views)
Accepted by topic author 4j1a
Thank you for contacting me about my dilema.
I was not aware of it, but myRio configuration
had saved it's self automatically, and the
function of this module was complete.
I am now able to operate myRIO wirelessly.
4j1a
(5,701 Views)
