current measure 6008
Hello everyone,
In my previous post i made a mistake of writing 1000 Amps instaed of 10 Milli amps. So can we measure 10milliamps from USB 6008 ? How can i measure current with DAQ i dont want to measure voltage and then divide it by resistor value. Is there a direct method of measuring current ?
I am using DAQ 6008 and wanted to make sure what is the minimum current which it can measure. Also, is there a documentation on how to directly measure the current ? instead of using I = V / R. The reason being my project is temperature sensitive and will be powered on "the entire day". Hence, i am looking for a solution which can allow me to measure current with out change in temperature.
My minimum current to be measured is 10MILLI Amp.
(2,884 Views)
duplicate post
Why you you post an identical question when it has already been answered? If you have additional questions, keep them to the original post. Otherwise, yuo just end up wasting someone's time.
(2,881 Views)
