API calls in a for loop (or not).
Which one of the two methods (top or bottom) would you think is more efficient / best performance (faster)?
thanks in advance!
Richard
(3,611 Views)
The bottom one since Mean.vi is reentrant.
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
(3,608 Views)
Of course in the top one you should be autoindexing the for-loop. Smiley Wink
(3,596 Views)
Excellent! Sometimes smaller / more compact isn't necessarily better.
Richard
(3,590 Views)
Provided there are resource contentions and the parallel function play nice together, a bunch of parallel paths will almost always run faster on multi-processor machines.
If the CPU only has a single core, the results may be different (but that is a point that will quickly fall into obscurity).
Ben
(3,586 Views)
Therein lies the crux. The technically correct answer to the question is: faster/more efficient under what conditions? Would the same hold for a single processor with hyperthreading? That's why I never too much stock in absolutes. Smiley Wink
(3,574 Views)
