current vi reference
Hi I'm new to Labview. I want to know how to get the current VI reference as the graph shown below. Functions>Application Contrl>Class Specifier Constant, but I couldn't find the VI option in its VI server class option.
Message 1 of 10
(7,783 Views)
As far as I know VI references are big rectangles:
Cheers
Message 2 of 10
(7,759 Views)
I think they work the same way. I am just curious where is it from. There is no mark ahead any of its options.
Message 3 of 10
(7,744 Views)
Yeah, that is weird. Can you attach the control, or the VI?
You can't even cast a Generic reference to a VI reference because they're two different things reference types.
Cast VI Ref.PNG< This throws an error
Cheers
Message 4 of 10
(7,738 Views)
Attached is that part of the vi file. Thank you very much for your help.
Message 5 of 10
(7,723 Views)
Ah, I'm back in 2014 still, no 2015. Maybe this is something new in 2015?
Cheers
Message 6 of 10
(7,717 Views)
The code is made in LV 2013, I just copy it to my LV2015.
Message 7 of 10
(7,714 Views)
Accepted by topic author Xinghe.W
The only way I know how to create a 'VI' class specifier constant is the following:
1. Drop a Class Specifier Constant and select it.
2. Press Ctrl-Space.
3. Type "VI".
4. Press Ctrl-B (the 'VI Server Rename' shortcut in Quick Drop).
There may be another way to do it, but this is the only way I know of. This functionality is available in LabVIEW 2010 and later.
Message 8 of 10
(7,706 Views)
That code is from the JKI state machine. OpenG has a "Current VIs Reference" vi that you can use to quickly get the reference.
Message 9 of 10
(7,702 Views)
Thank you, this solved my problem.
Message 10 of 10
(7,692 Views)
