cursor
I want to implement multiple drag-able cursors on the image graph (from a CCD camera) during image acquisition. I need the cursor (cross) for laser beam alignment on the camera. I want it to be drag-able and/or to be able to set the X,Y coordinates of the center of the cursor to move it to the desired position on the image.
What are the easiest options? I am using LV 2009.
Thanks!
Message 1 of 8
(5,287 Views)
femtovahan-
Are you using the NI Vision Acquisition Software for the image acquisition with your camera?
Mike S
NI AE
Message 2 of 8
(5,239 Views)
Yes, I do use Vision.
Vahan
Message 3 of 8
(5,227 Views)
Accepted by topic author femtovahan
Never mind, I figured a way to implement this using IMAQ Overlay features.
In case someone needs it, see attached. This can be usaed as a sub VI for displaying the cross on the image, specifying the X and Y coordinates of the center of the cross.
Thanks!
Message 4 of 8
(5,197 Views)
Hello, I'm using labview 8.5 and can't view the vi that you've made. I was wondering if it would be possible for you to post an image of the vi so that I can have a look at it. Thanks
Message 5 of 8
(4,958 Views)
Sure, see attached. Let me know if you still can't make it work.
Message 6 of 8
(4,930 Views)
Thank you, but what is the function next to the IMAQ function? i cant seem to find it.
Message 7 of 8
(4,922 Views)
The go in this order: IMAQ, IMAQ Copy, IMAQ Clear Overlay, IMAQ Overlay Line, IMAQ Overlay Line
Message 8 of 8
(4,914 Views)
