custom background not working
I have been using different background images on my front panels for years. Never had a problem until now. Now they appear to not be working. No custom backgrounds work, not even the LV provided (steel, wood, clouds, etc) ones. I can see them in the browser but they won't go to the front panel background. Win 7 and LV2012. Can anyone duplicate this behavior?
PaulG.
Retired
(3,039 Views)
Works fine.
Set to steel in edit mode manually.
Compiled to exe on xp, deployed to Win7 embedded.
George Zou
(3,024 Views)
Hi Paul
I can't seem to duplicate what you are seeing. Can you share a little more about the situation? You are using LabVIEW 2012. Has it ever worked for you before on 2012? It seems to be a pretty straight forward proceedure.
Ryan
Applications Engineer
(3,003 Views)
I can't get background image on another machine, either. Both are Win 7 running LV2012. No trouble in 2011.
Both machines have a "coporate" version of Windows 7. That might be an issue. I have had nothing but trouble with it. Don't know how else to test this on a "clean" Win 7 install other than to take everyone's word for it. Thanks. Smiley Happy
PaulG.
Retired
(2,990 Views)
Accepted by PaulG.
This might not be very convenient but you could try this to test you system.
https://decibel.ni.com/content/docs/DOC-5882
Ryan
(2,984 Views)
This works. Not the first time I've had to hard-wire a solution with property nodes that used to work from the front panel or vi properties. Smiley Indifferent
PaulG.
Retired
(2,977 Views)
