custom header delimeter
My company is used to exporting data from MAX using a custom header with the tab delimeter.  I am trying to make a LabVIEW program that automatically writes the data and header to the file.  My company already has software to make a custom header text file but the problem is that this file contains the text:  {delimiter} where each tab should be.  Is there a way when reading this custom header from the file to add a tab when this {delimiter} shows up such as MAX does?
(2,677 Views)
Use "search and replace string",
  • search string= {delimiter}
  • replace string=tab diagram constant
  • replace all=true.
(2,674 Views)
