how to create an application containing CWGraph3d with LV7.11
Hi all,
can anyone provide an step-by-step instruction on how to  create an application containing CWGraph3d with LV7.11? I have extensively searched the forums and tried to follow what I have found but with no success.
I have created a quite simple VI that takes some simple 2D data and plots a contour diagram from it. It was derived from '3D Surface Example - Fluctuating Sine Wave.vi' ant literally took me some 5 minutes to finish. Even the build app on my machinesimply ran fine.
But on a colleagues machine it installed fine, but missed the CWGraph3d.ocx and later had some versioning problems. I am at end here. Can anyone help me out with such an instruction? Or can LabVIEW 7.11 simply not do this?
Disapointed...
Greetings from Germany!
Uwe
(2,906 Views)
Did you build an application, or an installer? Have you looked over this document:
What Are Some Advanced Abilities of the LabVIEW Application Builder?
(2,904 Views)
Smercurio,
I have read, understand and followed the referenced doc, at least I believe so.
I did both, building an app AND an installer, as the colleague does not have LabVIEW. And I am quite familiar with apps and installers, as I have built a bunch of them for our production floor. Those did, however, not contain Active-X controls...
On my machine it worked just fine, App & installer have been successfully created and the exe runs fine. The installer run fine on the target machine, but the exe does not.
I have now created a virtual machine with a 'naked' XP, and in this VM the exe does'nt run as well. Seems to have to do with the ActiveX. I hav found a 'cw3dgrph.dep' on my machines C:\WINDOWS\system32 dir and have included the dlls as mentioned there as dynamic or support files in the AppBuilders 'Source files' tab. I have also marked 'Run executable after installation' in 'advanced installer settings' and have named 'reg32.exe' as executable and 'c:\windows\system32\cw3dgraph.ocx' as command line argument. I have also included the LV Runtime, '3D Graph Support' and 'Analyze VIs Support'. There is nothing more I can imagine.
Any ideas?
Uwe
(2,899 Views)
An update:
I have done some testing on this, but have to stop it for now. Maybe later...
It looks like it is a problem registering the ocx and the dependend dlls. Have found some threads on this forum.
My VirtualBox as a test vehicle stopped working after an  update of the naked XP to SP2, but before it had much older versions of the dependend dlls on it. I wanted to check if the dlls are updated by the SP2 or if they came from NI.
Anyway, it might take several weeks until I am able to continue exploring this behaviour.
I'd prefer if NI could provide a cookbook with all the background and steps to get this stuff running - not only in LV, but also in installed apps!
Uwe
(2,869 Views)
