custom scripting nodes
Is it possible to create custom scripting nodes, like the scilab one here
https://www.ni.com/en/support/downloads/tools-network/download.labview-to-scilab-gateway.html
 for interfacing with another language.
I looked in the download but couldn't find the code for interfacing scilab with a scripting node.
(4,592 Views)
No, you cannot create a new LabVIEW script function. Depending on the language, you could use a Call Library Function Node or the system exec. Do a search for Python or tcl to see how people have interfaced to those.
Don't understand your last question at all. You posted to the Scilab link and that has a link to the download with the script function.
(4,577 Views)
Are you sure this just isn't a hidden feature, like xnodes???
(4,565 Views)
Have you seen LabPython?  I don't know how they did it, but they sure did it.
Jim
(4,525 Views)
strangely enough, when i tried it i couldnt find this. in fact, i  only found i was able to write code in text boxes.
(4,512 Views)
Hi Gordal,
It is possible to create custom script servers, just like the way scilab scipt nodes work. However, I don't know of any references on the subject. All they really do behind the scenes is call a DLL and output the results. I would recommend a simliar appoarch.
Hope this help and good luck!
Joe Daily
may the G be with you ....
(4,492 Views)
