labview
if i use many modules as gps gsm to be connected with microcontroller using labview, must all components be NI or the microcontroller only
(3,162 Views)
I think most GPS and GSM units do communication by some sort of serial protocol. So in that case you use Labview to write software communication with the device. The device do not have to be NI at all
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,141 Views)
National Instruments does not currently make an Microcontrollers. You can target Blackfin or Arm processors using LabVIEW Embedded, or you can use a Programmable AUtomation Controller like CompactRIO to work with GPS modules. I recommend you check out our Embeded Systems Design Homepage.
-Hunter
(3,079 Views)
