cycle accurate simulator for FPGA
hello
I want to use evaluation version of "cycle accurate simulator" tool for FPGA module as it help in Verify FPGA vi in waveform environment and save time.
Please help me for the same .
regards
Message 1 of 8
(3,125 Views)
Have you gone through the help document:
http://zone.ni.com/reference/en-XX/help/371599F-01/TOC29.htm
If so, then what kind of help do you need?
Adnan Zafar
Certified LabVIEW Architect
Coleman Technologies
Message 2 of 8
(3,120 Views)
i want link for download evaluation software for cycle accurate simulator
Message 3 of 8
(3,114 Views)
You mean for ModelSim? Have you tried going on their webpage and accessing the software?
Adnan Zafar
Message 4 of 8
(3,104 Views)
I have modelsim with me but when i  click " tool button " in  labview fpga vi it does not show option to bind it with modelsim simulator.
How will i bind my vi to modelsim simulator to see waveform and run test bench.
Message 5 of 8
(3,098 Views)
Did you follow the steps that are mentioned in the link in my first post above:
http://zone.ni.com/reference/en-XX/help/371599F-01/lvfpgahelp/fpga_simulation_step_outline/
You will need to create a simulation build before you do anything.
Adnan Zafar
Message 6 of 8
(3,094 Views)
when i click build option on Project window  no option for Simulation Export appears.
I am using 2009 FPGA version .I dont know whether it support cycle accurate simulation.
Do i  need to install any another tool for cycle accurate simulation? I have FPGA module installed with me.
Message 7 of 8
(3,088 Views)
Dear Sir
I am using Modelsim 6.6 B PE  software.When i try to update simulation library it shows error.Error message is"Your Modelsim
Directory is read only".I change directory attribute but it again shows error.Please suggest me how to cop up with problem.
Is labview is compatible with modelsim 6.6 B PE edition.
Please help for the same
Thanks in advance
Gaurav
Engineer
WESEE
Message 8 of 8
(2,986 Views)
