downconvert IQ data that not centered around zero
Hi all,
I want to downconvert IQ signal that is not centered around zero. I don't wan't to use the MT downconvert passband VI with its complex input mode selected...One option could be that i upconvert the signal to some higher frequency say 'freq1' and then downconvert freq1 to zero but for this i'll have to resample the signal first at least 2*freq1 that i don't want to do, coz it requires more processing. Is there any way to directly perform downconversion without doing upconversion and resampling?
thanks
(3,886 Views)
If you know the center frequency if the IQ data then just multiply by cosine(2*pi*fc*t) for the I part and sine(2*pi*fc*t) for the Q part.  Lowpass filter both signals to remove the higher frequency component. What is the sampling frequency and the center frequency of the data?
Randall Pursley
(3,865 Views)
I have acquired a band of 4MHz IQ data that is centered around zero with an IQ rate of 5MHz. So, the spectrum spans from -2.5MHz to +2.5MHz. This 4MHz band has one signal centered around +1MHz, one centered around 0, and another one centered around -1MHz. All three signals have a bandwidth of 200kHz. I want to down convert the +1MHz and -1MHz signals to zero.
(3,848 Views)
I think, and I haven't had a chance to verify, instead of mixing down by multiplying with a cos(2*pi*1MHZ*t) or sin(2*pi*1MHZ*t), you need to multiply by [cos(2*pi*1MHZ*t) + i*sin(2*pi*1MHZ*t)] for the 1 MHz signal and by [cos(2*pi*1MHZ*t) - i*sin(2*pi*1MHZ*t)] for the -1 MHz.  The complex sinusoids should give you only one impulse signal, if you are looking in the frequency domain, to convolve against.
Randall Pursley
(3,823 Views)
Thanks. It works!
(3,781 Views)
