daq scaling and input error
Accepted by cuthbert
Please try to use one of the shipping examples so that we can sort out any problem with your code. You can use an example such as "Cont Acq&Graph Voltage-Int Clk-Analog Start" . You can go to Help>>Find Examples>>Hardware Input and Output>>DAQmx. Tell me if you still see a discrepancy between the two graphs by using this example.
Yupeng J.
Message 11 of 13
(1,197 Views)
you were right about setting up the max and min - now it runs OK.
Message 12 of 13
(1,186 Views)
This can happen when you have a set up your terminal type to differential but you use a grounding terminal that is not associated with that AI block.
you can move your grounding terminal or change your terminal type to RSE.
Message 13 of 13
(915 Views)
