08-08-2005 10:15 AM
nilibs=-lnidaqmxbase -lnidaqmxbaselv -llvrtdark -lserial
includes=-I../../include
includes1= `pkg-config --cflags --libs gtk+2.0`
flags= -O2
cc=gcc
ai_examples = sergra
all : $(ai_examples)
% : %.c
$(cc) $(includes1) $(includes) $(flags) $< $(nilibs) -o $@
clean :
rm -f $(ai_examples)
The code works fine !! no errors whilst compiling but when I try to run my program I seem to get an error.
I understand that my c code is just a wrapper. But I dont have a labview directory and I am not able to understand whats up with the linking.Anyone got any ideas??!!
08-09-2005 05:57 PM
Hello-
The file in question should actually appear in the "/usr/local/lv71/AppLibs" directory on your drive. The file (I have attached to this message) seems to describe the problem you're seeing- that the application will link correctly but will crash unexpectedly due to a bug in some versions of Solaris and RedHat Linux. I had to change the extension to ".txt" to get the forum software to allow the attachment to pass.
Please take a look at this file and let us know if you're still seeing problems.
Thanks-
08-10-2005 12:57 PM
Tom,
Thanks for your quick response. My situation is almost the same but not quite! When I installed daqmx base I had installed NI-VISA, all the other tools and the C API. But I reckon labview was not installed since I do not have the directory."/usr/local/lv71/AppLibs" . I was also unable to find the files SharedLibs.so,folders cintool or lv61. Also my program does not make direct use of labview but uses the C API. I know my C program is just a wrapper and it has labview underneath it. I am assuming it is accessed somewhere from /usr/local/vxipnp/linux. I have a choice of reinstalling daqmxbase (with labview). But am not sure I need to do that as I am able to aquire data with my current status.Hope I have given you a sufficient background to help me.
Prem
08-11-2005 11:56 AM
Hi Prem-
You may indeed need to have LabVIEW installed in order to work with your graphical interface because certain variable type libraries are necessary that are not included with the NI-DAQmx Base driver directly. The driver itself is written in LabVIEW, so even though you are using the C interface the LabVIEW RunTime engine will still be running all of the interfaces. The graphical front end you are using seems to have difficulties interfacing with the RunTime engine, so these additional libraries are needed. It sounds like your non-graphical approach is working fine, so the hardware and programming seem to be in line.
After installing LabVIEW you will need to reinstall the DAQmx Base driver and then modify the search directory suggested by "gcc -o myapp myapp.c -I/usr/local/lv61/cintools SharedLib.so -llvrt -lpthread" to reflect your version of LabVIEW (i.e. lv71 for LabVIEW 7.1). The necessary files should then be included.
Please let me know if you still aren't able to compile after taking these steps and I will investigate further.
Thanks-
08-11-2005 08:47 PM
08-22-2005 12:57 PM
David, Tom..
Sorry about the delay but I wanted to try out both your suggestions. Davids suggestion about refering to the correct directory does not seem to work. My application is in /root/Desktop/wcp . So I tried to refer to the correct directory as -T../../../usr/local/natinst/nidaqmxbase/include. I am still getting the same error( it is worth mentioning that the only file in this directory is nidaqmxbase). I tried toms technique. uninstalled nidaqmxbase, installed lab view and then reinstalled nidaqmxbase. I aslo went through the readme you had suggested. From it I gather that my include is -I../../../usr/local/lv71/cintools ( going by current directory. ) I also included -llvrt and -lpthread as my nilibs . I however could not find the file sharedlib.so ( or are we creating it ?) . I am including my make file for reference. I still do get the same error.
nilibs=-lnidaqmxbase -lnidaqmxbaselv -llvrtdark -lserial -llvrt -lpthread
includes=-I../../../usr/local/lv71/cintools
flags= -O2
cc=gcc
% : %.c
clean :
08-23-2005 02:32 PM
Hi Prem-
I do not see in your makefile where you reference the directory suggested by David. Are you able to see better results by referencing the directory directly as suggested by David rather than using the relative path structure "-T../../../usr/local/natinst/nidaqmxbase/include" ?
08-23-2005 03:03 PM
Tom,
I have tried davids method it does not work. Besides the error message says the runtime engine failed to initialise. Davids include points to just one file nidaqmxbase.h .
08-24-2005 05:36 PM
08-29-2005 10:28 AM
Tom,
I undertstand what your saying. I just have now more question. In the readme file that you mentioned ....there is a file called sharedlib.so ....where is this file if it exists...because it is not there on my system
