error -41 LV8.6 application builder
I am trying to build an installer and I am getting this error -41 (unknown origin). I am using Visa with three instruments.
Here is what is says :
CDK_Build_Invoke.vi.ProxyCaller >> CDK_Build_Invoke.vi >> CDK_Engine_Main.vi >> CDK_Engine_InitializeDistribution.vi >> NI_MDF.lvlib:MDFConfig_SetBuildDir.vi
C:\Documents and Settings\Nusi\Mes documents\recherche\labview\Builds\rho_ac\rho AC "version light"
Chargement des informations sur le déploiement des produits
*** Erreur : Une erreur interne de cause inconnue a eu lieu (code d'erreur -41)).
*** Fin du rapport d'erreurs
For the details I got :
Visitez la page de demande de support sur ni.com/ask_fr pour en apprendre davantage sur la résolution de ce problème. Utilisez les informations suivantes comme référence :
any ideas ?
thanks a lot
(2,779 Views)
Your description reminds me on some unexpected errors which I had while building my application. But I don't remember exactly what happened. On point were missing external files. This does not affect the building of the application but the installer cannot finish. I suggest to look carefully thru your project and see whether there a missing files. The other time I think there was a VI being not part of a class or something like that. But that should be detected while building the application. So I don't remember it exactly but I hope it will help you to find the problem yourself.
Regards
(2,757 Views)
