daqmx digital output help
Message 11 of 14
(617 Views)
I need some help. Still trying to get my timing figured out for digital outputs.
I have now installed a 9401 DIO card which has coorelated DIO.
Yet the only way i can get the daqmx timing to not create an error is by using PFI0 for the source.
When i do the output waveform which should take 4 seconds, it is performed in about 20 ms.
I dont understand where is my mistake.
have attached hardware and vi.
Any help is greatly appriciated
Message 12 of 14
(585 Views)
Anyone?
Message 13 of 14
(566 Views)
Solved.
Thanks to:
https://forums.ni.com/t5/Example-Code/NI-DAQmx-Correlated-Digital-I-O-with-NI-CompactDAQ-and-LabVIEW...
For what seemed like such an easy task it sure was a bitch.
Message 14 of 14
(546 Views)
