daqmx error when deploying to RT
Hello everyone,
I'm getting a Daq-mx error when I try to run my RT executable on my PXI system. I was previously getting error -50352 when running the executable, and a suggested fix was to upgrade to the latest DAQ-mx drivers (9.0). Did this, and updated my RT target to have the same driver version. Now am getting this message when using the "run as startup" option to deploy my rt executable.
"NI-DAQmx could not deploy the item to the target because a connection could not be made. Deployment can fail due to network failure, NI-DAQmx not being installed on the target, or different versions of NI-DAQmx being installed on the host and target."
This is my current system configuration:
LV8.5
DAQ-mx 9.0.0 (installed on host and pxi)
Controller PXI-8106
PXI-6154
PXI-6624
PXI-6229
NI-MAX 4.6.1f0
Any suggestions would be appreciated.
Thanks!
Message 1 of 16
(5,902 Views)
Do you receive the same error when you just run the VI from your project?
Have you confirmed proper connectivity with your controller?
Can you run test panels on your DAQmx devices that are in your PXI Chassis in MAX?
Message Edited by Will S. on 09-15-2009 11:38 AM
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Message 2 of 16
(5,881 Views)
Hi Will,
Yes, I do recieve the same error when running the VI from the project. The daqmx tasks run from max (as well as the test panels). I have also created a RT new project using the NI project wizard and have been able to deploy succesfully (i didnt create any tasks for this project, just did some basic analog input).
Seems to be something specific to my project and the tasks it calls.
Message 3 of 16
(5,865 Views)
I would suggest disabling individual tasks in your project until you can identify the specific task that is causing the issue. Or is it the act of creating a task that causes the issue?
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
choose-mc.com
Message 4 of 16
(5,850 Views)
As a workaround, I have exported the tasks and scales from my project and imported them into NI-Max and deleted all tasks and scales from my project. Seems to work for now, just curious as to why I cant start tasks that are within my project???
Message 5 of 16
(5,836 Views)
Since you can create new VIs and execute DAQmx tasks within them, it appears that something is amiss with at least one of the tasks you had in this specific VI. In order to find out why I would still suggest attempting to isolate the individual tasks until you find the one causing the error.
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
choose-mc.com
Message 6 of 16
(5,819 Views)
Hi there,
sorry for posting into this thread a bit late, but I have exactly the same problems as the original poster. If I generate a RT project with the project wizard and do not modify anything, I can deploy to my RT target without problem. As soon as I add a virtual channel to the project (doesn't seem to matter if input or output channel), the deployment fails with the error described by the OP.  I can also work around this by exporting the channel and importing it into MAX.
My software configuration:
LV 8.6 on WinXP SP3
LV RT 8.6 on a desktop target
DAQmx 9.02
MAX 4.6.1f0
If I just use the DAQmx VIs from the functions palette, I can deploy the project without problems.
Regards
Stefan
Message 7 of 16
(5,654 Views)
Hi Stefan,
Do you have a simple project that reproduces this?  Also, are you adding the virtual channel to the Host (My Computer) or the RT target? What is your RT target?
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
choose-mc.com
Message 8 of 16
(5,612 Views)
Hi Will,
as an example I used the project wizard to create a new Real-Time project with continuous communication architecture, one loop on the target, and a host user interface VI. Deployment of this on my standard desktop target with LabVIEW RT 8.6 works fine. As soon as I add a virtual channel the deployment fails. I have reinstalled the RT target system from scratch, but that did not help. I don't know how to send the project files to you, so I include two screenshots instead.
Let me know if you need anything else to get an idea of what is going on.
Regards
Stefan
Message 9 of 16
(5,605 Views)
Hi Stefan,
Do you have the same version of drivers installed on your host and real-time controller?
Will
CLA, CLED, CTD, CPI
LabVIEW Champion
choose-mc.com
Message 10 of 16
(5,587 Views)
