daqmx error when deploying to RT
Yes, I have DAQmx 9.02 both on the host and the target. I have reinstalled the drivers just to be sure, but no luck.
Cheers
Stefan
Message 11 of 16
(1,781 Views)
Hi Stefan,
I can't seem to reproduce this on my side. You can attach documents by clicking the "Add Attachments" link just below the Post button when you make a new post. If you can zip a basic project and VIs that demonstrates this issue, maybe we can see it over here.
Will
CLA, CLED, CTD, Former CPI
LabVIEW Champion
Choose Movement Consulting
choose-mc.com
Message 12 of 16
(1,763 Views)
Hi Will,
I have created two projects for you. The first one I can deploy successfully. The second project is identical to the first, just with an added virtual channel, which produces the deployment error.
Best wishes
Stefan
Message 13 of 16
(1,753 Views)
Hi Stefan,
I still can't seem to reproduce the issue on my side. Have you tried reformatting your RTPC and trying again? Or perhaps repairing LabVIEW and LabVIEW Real-Time on your host computer?
Will
LabVIEW Champion
choose-mc.com
Message 14 of 16
(1,708 Views)
Hi Will,
I have tried all that. In fact, I have setup the whole system (host and target) from scratch three times. I guess I will have to live with this issue - at least there are ways to work around it.
As a sidenote, I have also tried to use LabVIEW 2009, but then I was not even able to deploy anything to the RT system (which I upgraded to RT 2009 of course). Maybe the hardware I'm using is "funny" in some way...
For now I'll stick with 8.6 and work around the issue with the project virtual channels.
Thanks for your help, I appreaciate it!
Stefan
Message 15 of 16
(1,703 Views)
found this thread because I ran into the same problem updating to LabView 2009 (+RT on a PXI system) and DAQmx 9.1 from LabView 8.6.1 and DAQmx 8.9.
Seems to be a problem of the DAQmx9. After deinstalling 9.1 and installing DAQmx8.9.5 (the first version recognizing LabView 2009) my project tasks deploy again.
Regards
Matthias
Message 16 of 16
(1,509 Views)
