daqmx event error
hi
ive trying to execute an event using DAQmx event structure, but when running im getting an error,
Does anybody know how to run this properly?
thanks!
attached picture
(3,950 Views)
Giving the error message the benefit of the doubt for the moment, are you sure the DAQ device you are using supports this event? Not all do.
What device(s) do you have?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,932 Views)
hello
The device im using is USB-6341 multifunction DAQ, i dont know exactly how to use DAQ events, so if you have an example i'll appreciate it
thanks!
(3,885 Views)
Well its fairly straight forward that a digital in line will never accumulate a terminal count A Counter Output Event is only available for counter input tasks.
The DAQmx help file lists the events and a discription of what they do.  You are probably looking for a change detection event.
(3,877 Views)
In fact, im looking for a change detection
(3,870 Views)
Accepted by topic author Tokyghy
Something like this?
Best Regards,
John Passiak
(3,846 Views)
Yes something like that!
let me try that code, i'll let you know if it works
many thanks
(3,819 Views)
