daqmx simulated digital input
I'm having trouble using the simulated digital input feature.
I create a simulated digital input in MAX - a simulated NI PCI-6534, single channel, port 0/line 0, acquisition mode is 1 Sample (On Demand)
When I click the "run" button I see the indicator flash on and off as I would expect.
However, when I bring this task in to LbView, I can't get the indicator to flash no matter what I've tried.
No doubt I've missed some basic concept. Can anyone tell me what I'm doing wrong?
(VI attached).
Message 1 of 8
(7,773 Views)
Hello DennisW
We cannot reproduce the issue since you are referecing a task configured in MAX and you just sent a VI.
However, if your task is working in MAX, you could use a DAQ assistant in LabVIEW using the same configuration as in MAX.
Using the DAQ Assistant to Automatically Generate LabVIEW Code
Regards
Frank R.
Message 2 of 8
(7,742 Views)
But I did give the steps I took to create the simulated digitial input - NI PCI-6534, single channel, port 0/line 0, acquisition mode is 1 Sample (On Demand)
It should take just a few clicks in MAX to create it.
I don't understand why it would work differently than using the DAQmx assistant, since the set-up is the same.
Using LabView 2014 32-bit, DAQmx 14.0 on Windows 7 64-bit.
Message 3 of 8
(7,723 Views)
You do not have N channels, you have 1 channel.  Use the appropriate DAQmx Read version.
Message 4 of 8
(7,712 Views)
OK, tried that, no difference
Message 5 of 8
(7,697 Views)
Accepted by DennisW
Try starting the task explicitly before the loop (and clearing the task after the loop):
Best Regards,
John Passiak
Message 6 of 8
(7,688 Views)
This worked for me ...
Message 7 of 8
(7,680 Views)
Makes sense! Works too.
Thanx!
Message 8 of 8
(7,673 Views)
