dark blue line? Why?
I have made an Lv in 6.0. I have have a for loop. I have made connections to i. The line is dark blue/black. Is something wrong? The Lv is attached.
(3,098 Views)
Blue is correct, [i] is an integer.
Integers have blue wires, floating point numbers are in orange. If you need to convert it to DBL, use "to DBL" from the conversion palette.
(3,093 Views)
