data.ctl
A data.ctl is connected with a state machine. I deleted the data.ctl file by mistake, now I want to create another one, but I didn't find the function.   Can anyone tell me how to create a data.ctl?
(5,715 Views)
Hi cantata,
create a control for that wire. Then save that control as (new) typedefinition…
(5,690 Views)
Sorry I misread the original post
Bill
CLD
(Mid-Level minion.)
(5,603 Views)
Hi, there was an independant data.ctl file before, but I deleted it by mistake.  Now the front panel looks like this:
The previous settings are still there, but they can't be used. How can I make them real and save as type definition?
(5,568 Views)
If you've got a picture of the Control (like you attached), simply open a new VI, drop down a blank Cluster on the Front Panel, and start building.  Start with a Boolean Control, name it Run?.  Find where you use the WANL Reference (on your Block Diagram) and create a Control there, name it WANL ref and add the Control (on the Front Panel) to the Cluster, add a Numeric called Counter, etc.  When you have the Cluster all made, right-click it and "Make Type Def".  Now open Type Def and do any final editing (maybe name it Data) and save it somewhere with a suitable name.
Bob Schor
(5,557 Views)
Or select to disconnect from typedef, select to edit the control, and save it in the control editor.
(5,549 Views)
Is it in the recycle bin?
Bill
CLD
(Mid-Level minion.)
(5,478 Views)
