data logger to spreadsheet file
The VIs in the llb you attached do not have any diagrams and they can't be opened in my version of LabVIEW. I hope you have a backup since once you remove the diagram, it's gone forever.
Message 11 of 22
(1,411 Views)
I tried to do again. Hope u can open this attached file.
Message 12 of 22
(1,408 Views)
They still have no diagrams. this is something you can verify yourself. Just open one of the VIs and try to go to the block diagram. If you are creating this llb from separate VIs, how are you doing it? You should just be using the Save With Options>Development Distribution. DO NOT select Application Distribution. As you can see by the options for this, it automatically removes diagrams.
Message 13 of 22
(1,406 Views)
Sorry. Let me do again.
Message 14 of 22
(1,400 Views)
Message 15 of 22
(1,401 Views)
Whatever you are doing, you keep repeating the same mistake. You screen should look something like this. Delete any old llb of the same name and try again. Before posting, actually look at what you have created. If you can go to a VI's diagram, then it's okay.
Message Edited by Dennis Knutson on 12-29-2006 02:00 PM
Message 16 of 22
(1,396 Views)
It's very strange. I  did the same things, but i couldn't get it. Neither i can see the diagram. The folder is empty. I can't understand what's happen in my labview, anyway, i will check again. Thanks a lot and happy new year
Message 17 of 22
(1,379 Views)
Hello, Denis
Two questions:
I think i had removed the diagrams, how can i do for this problem?
I tried to download and correct the ancient VIs from the earlier edition that i had uploaded to this board. I can see the diagram. So i think this time it can work.Can i use this llb for resolving my problem? How can i do?
Thanks a lot
Message 18 of 22
(1,372 Views)
You've got your program back! To continue with the original question, the error code -10007 means:
NI-DAQ LV:  A channel, port, or counter is out of range for the device type or device configuration; or the combination of channels is not allowed; or the scan order must be reversed (0 last).
I don't know where you got the description that you posted. It would seem that your channels are not correct. I'm not that familar with the DAQcard 700 and I don't know if the reversing of the channel order must be done for this. It's something that can be tried. Was this card used with the orignal program?
Message 19 of 22
(1,359 Views)
yes, this card use only for this programme, but, the older computer was out of order, and we changed to install to the other notebook. I had tried many times to reverse the channels, but not useful. i had also reinstalled ni daq device several times, but got the same result. i don't know what i can do?
Message 20 of 22
(1,345 Views)
