data table how to separate?
Hey everyone,
How do I separate the data array, which are in columns txt file for analyzed and graph displayed?
Marek
(2,747 Views)
Accepted by gfds
Use the index array function located in  Programming - array - index array.
When you connect a 2D array to that function it will give you the option to index by columns or rows.
Hope this helps,
Paulo
(2,745 Views)
Thanks Paulo for your help. It works as you said.
Marek
(2,736 Views)
