data table how to separate?
Hey everyone,
How do I separate the data array, which are in columns txt file for analyzed and graph displayed?
Marek
(2,741 Views)
Accepted by topic author gfds
Use the index array function located in  Programming - array - index array.
When you connect a 2D array to that function it will give you the option to index by columns or rows.
Hope this helps,
Paulo
(2,739 Views)
Thanks Paulo for your help. It works as you said.
Marek
(2,730 Views)
