data types in formula nodes
Hey People,
A silly question: How do I initialise a double variable in a formula node? I tried writing it as double y, and dbl y, etc etc,
but that didnt work. The example given was int32 y, which worked, but i need a double variable.
thanks a lot 🙂
(3,666 Views)
Accepted by LSASS
SOLUTION FOUND 🙂
(3,662 Views)
Rather then just saying you found the solution, and marking that reply like it was the solution, perhaps you can put in your reply as to what your solution was?
That way anyone searching the forums for the same problem can learn from your experience.Smiley Wink
(3,641 Views)
