database connectivity
@Yamaeda wrote:
Since it's the Execute query that generates the error i assume the question is somehow ill formed. Date, e.g. might be reserved and not allowed as column name. Try the query directly in the database before placing it in code.
/Y
Ah! Yes - I seem to remember that 'date' is a function in SQL - try escaping the time and date column names (e.g. with a tick ` or an apostrophe ' - I forget which)
(blog)
Message 11 of 21
(2,736 Views)
Hi Yamaeda,
I have run the query directly in the database and the query returns the right data.
regards
Matt
Message 12 of 21
(2,734 Views)
If accessing Access or MSSQL it's often good to use [] around column names ( [date] ).
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 13 of 21
(2,722 Views)
@Matt14122017 wrote:
Hi Yamaeda,
regards
Matt
Then you need to tell us what the full error message is!!
(blog)
Message 14 of 21
(2,716 Views)
Hello Sam,
Here is the full message error.
regards
Matt
Message 15 of 21
(2,706 Views)
Look at the query string in the error... you have your query in the box which ends with "ORDER BY time;" but then you concatenate "Pavilion (Retail)" at the end of it - which isn't a valid query.
(blog)
Message 16 of 21
(2,696 Views)
How did you get your Amazon timestream to Connect to LabView Successfully? , Please help
Message 17 of 21
(1,289 Views)
how about capital letters in the column names? Then you have to use " "  as in "Capital" otherwise Capital turns into capital, column does not exist
I made my software so it shows the actual string that goes into SQL, then I can copy paste that into SQL admin and run
Message 18 of 21
(1,265 Views)
That's a good way to test things manually before trusting the program. 🙂
Qestit Systems
Message 19 of 21
(1,248 Views)
Note that the query issue is from an old 2018 thread that GUYFelix has resurrected.  He is only asking about connecting to Amazon.
@GUYFelix:  Adding to an old thread is confusing to the people that respond.  You are better off starting a new thread to ask your question.  ðŸ˜‰
Message 20 of 21
(1,238 Views)
