database support
what kind of database that I can use for client server that compatible with labview.
(3,098 Views)
Databases with an ODBC driver and SQL support. Databases with only an ActiveX interface. Databases with only a DDE interface. If it's been designed to allow external applications to access it, just about any database will do. ODBC/ADO and SQL are the easiest. These are supported by NI's database toolkit and an open source LabVIEW tool. I've used SQL Server, Oracle, Access, MySQL, dBase.
(3,098 Views)
You might want to check http://www.jeffreytravis.com/lost/labsql.html
(3,098 Views)
