datafinder error and install error
When I open my computer, an datafinder error would show up.
And if I reinstall everything, the installing program(labview 2011 sp1) would stop at dataloging part(I waited for at least 2 hours, nothing happened), and I have to quit.
Any ideas?
nan
(3,545 Views)
You can check this article
http://ae.natinst.com/public.nsf/web/searchinternal/85fc48ddf584fe8c86257937005455e2?OpenDocument
(3,509 Views)
Before running the installer try to make sure no NI software is runnning. Also shut down services named NI *. Then try to run the installer again.
(3,498 Views)
I posted an incorrect link. Here's the correct one:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P6uGSAS&l=en-US
(3,492 Views)
Unfortunately, the link does not help.
I looked into my PC, there is no config file under the USI folder...
But thanks for trying to help me though.
nan
(3,474 Views)
You maybe looked into the programfiles instead of programdata folder:
C:\ProgramData\National Instruments\Shared\USI\Config
(3,460 Views)
