datasocket and event
Hi to all,
currently I`m looking for a soulution to get a datasocket variable to work with a event structure...
Because if the datasocket event indicator is changing no event is call, so is there any possibility to combine a variable which is binded via datasocket and an event structure?
Tnaks a lot...
Chris
(2,899 Views)
Hi Chris,
if I got well what you meant oyu would like to fire an event when your datasocket variable changes.
Look at the KB hierunder:
Event Structure Does Not Capture the 'Value Change' Event When Values are Programmatically Changed
http://digital.ni.com/public.nsf/allkb/024828947672E68586256ADB0071FB1B?OpenDocument
Does it answer your question? If not can you post your code?
Best regards.
Andrea Perin
Application Engineer
(2,877 Views)
