datasocket and event
Hi to all,
currently I`m looking for a soulution to get a datasocket variable to work with a event structure...
Because if the datasocket event indicator is changing no event is call, so is there any possibility to combine a variable which is binded via datasocket and an event structure?
Tnaks a lot...
Chris
(2,978 Views)
Hi Chris,
if I got well what you meant oyu would like to fire an event when your datasocket variable changes.
Look at the KB hierunder:
Event Structure Does Not Capture the 'Value Change' Event When Values are Programmatically Changed
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019N6xSAE&l=en-US
Does it answer your question? If not can you post your code?
Best regards.
Andrea Perin
Application Engineer
(2,956 Views)
