datasocket, read when data changed in buffer
Hai
I am using datasocket to communicate between a remote VI on the PXI and a server application. Normally i would just write in to the datasocket server from the PXI, but if there is any data in the input buffer i need to read it and process it. Is there any Vi which or way in which i can check for data at input buffer.
Thanx for the answer
(2,686 Views)
Plese refer to "LabVIEW Function, VI and How-to help" and search for "datasocket, buffering data". Here you will find a snapshot of a VI that reads data from an Input buffer and also monitors how much buffer is being utilised.
Please let me know if you have more questions on this issue.
Ankita A.
NAtional Instruments
(2,686 Views)
