read file *.txt in real time
Hello
I have a pb with RT.
Is it possible to read a file *.txt directly on the pc RT ??? and not on the host pc !!
If it's possible, please tell me how??
Find my two programs with two pcs!!
it is to have a signal on the output rt NI PXI 6070E who is in the txt file.
Thanks a lot for your help
(2,551 Views)
You can access from youy host to your RT target by using the explorer or any ftp browser. Then, by ftp, or copy and paste, You'll be able to download your data file to generate. After, please use FILE I/I Vis from LabVIEW to access data from file.
Regards.
Vincent RUAULT
Application Engineer
National Instruments France
(2,551 Views)
