date comparison
Hello All
The attached vi searches a directory which contains txt files with the name format File_2011.02.17.txt...viz the file is named on the date it is created.
The purpose of the directory search is to determine if a file already exists....if it doesn't, then something else happens (this part of the code is not included nor is it relevant)
The date part of the file is created using the Get Date/Time in seconds format.
After searching the directory and finding the latest txt file I am then attempting to compare it with the current date.
This is where I'm having a little trouble, and would appreciate any assistance.
I'm sure it's a very minor thing to do, but I've always had trouble with timestamps, dates etc.
Thank you and best regards
Ray
Message 1 of 20
(7,536 Views)
Accepted by rayclout
You can use a simple regular expression to extract the date components from the file name. Then you can convert them to numbers and compare then at will. I would recommend calculating a Julian date from the components so you only need to do one comparison.
Mark Yedinak
Certified LabVIEW Architect
LabVIEW Champion
Message 2 of 20
(7,521 Views)
Hello Mark
Firstly thank you for your interest
I assume the function you have used here is a Match Regular Expression. I'm using LV2009 on XP, and this function I have looks different to yours. For a start it doesn't have the three seperate string outputs on the right hand side, but rather....before match, whole match and after match.
Am I missing something here?
Ray
Message 3 of 20
(7,511 Views)
Answered my own question....drag the bottom of the vi down to expand....simple
Message 4 of 20
(7,504 Views)
The Regular Expression function can be expanded by grabbing the bottom of the function and pulling down (like many other LV functions)
You could also drag Mark's example from your browser and drop it on your block diagram, it's called a VI Snippet.
Message 5 of 20
(7,503 Views)
Phillip
That process doesn't work for me.
See attachment for what drops onto my BD
R
Message 6 of 20
(7,498 Views)
Mark
I took your advice on all counts and it works. It may be convoluted and a knight could do it in half as many functions (have a look) but it does work.
Thanks again
Ray
Message 7 of 20
(7,489 Views)
Then please give credit to Mark for giving you the solution by marking his message as the solution and not your own.  You can unmark your message by going to the options menu to the upper right of your message.
Message 8 of 20
(7,477 Views)
@rayclout wrote:
Phillip
R
I'm  guessing you are using Firefox or Chrome. I think there is a known issue with these browsers. Internet Explorer should work.
By the way, I just upgraded my home laptop to IE 9 and now I can't drop a snippet using IE either Smiley Sad
Message 9 of 20
(7,457 Views)
Ravens Fan
Where did I mark my message as the solution and not Marks?
I must be going blind
Message 10 of 20
(7,442 Views)
