deactivate "insert element before / remove element" in array
Hi Dan,
I am dealing with the same problem.
The RTM of an array with numbers is different the RTM of the array. (when you click on the small area between the numbers and the panel)
I am still looking for a way to customize the numers in array RTM (insert row/ delete row/ insert col....).
anybody got an idea?
Message 11 of 12
(687 Views)
I found a way:
created a custom RTM and used the Tags: APP_SC_INSERT_ROW_BEFORE and APP_SC_DELETE_ROW
Message 12 of 12
(685 Views)
