decoration problem: how to appoint one picture on top of another picture?
i attach the VI
for example, i want to put labview logo on top of the clock
but i cannot 😞 what will be the right method?
i want to put pictures on top of this raised box, but i cannot, what will be the right method?
thank you!
(2,563 Views)
Accepted by ivy037
Find the Reorder button on the labview toolbar, then select the object you want on top and then select Move To Front in the reorder menu.
Select the Reorder pull-down menu when you have objects that overlap each other and you want to define which one is in front or back of another. Select one of the objects with the Positioning tool and then select from Move ForwardMove BackwardMove To Front, and Move To Back.
http://www.ni.com/gettingstarted/labviewbasics/tools.htm
(2,554 Views)
